Einleitung
Lost a stud on your Icebug shoes/boots?
No problems! Icebug's BUGrip technology is designed so that you will have a good grip even if you drop one or even a pair of studs per shoe. If, on the other hand, you lose more, you should add new ones - and you can easily do it yourself.
You can order the studs free of charge from Icebug's customer services. Email Icebug at info@icebug.se stating which shoe model you have. Send along photos showing the shoes in full and a clear image of the outsoles. Tell us how many studs you are missing, and to which address you want them sent.
With the help of the photos, we decide if it is worth sending out replacement studs. If too many are missing, or the shoes are too old or worn, it is not certain that the grip can be restored.
We will send your new studs shortly and you will then easily mount them there with elastic glue (for example RubberFix or Shoe Goo) and pliers.
See how it's done in the video here:
Einführungsvideo
New BUGrip studs
Elastic Glue (For example RubberFix or Shoe Goo)
Pliers
1. Clean the holes where you have lost studs
2. Fill the holes with glue
3. Apply the studs - tilt, push and twist
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Enjoy the outdoors!
