Einleitung
Replacing a worn door gasket keeps steam, odours and heat inside the oven, saving energy and protecting nearby cabinets. A working oven light lets you monitor food without opening the door and losing heat. Both jobs are quick beginner-level tasks you can handle yourself with minimal tools.
Was du brauchst
Schritt 2 Release the door gasket
Lift the small metal hooks along the door frame to release the gasket.
Work around the perimeter until the entire seal is free.
Schritt 3 Prepare the new gasket
Clean the groove and the gasket with a cloth to remove grease and crumbs.
Hold the gasket so it sits square with the stitched joint positioned at the bottom.
Schritt 4 Install the new gasket
Hook the first corner of the gasket onto the upper catch in the frame.
Stretch the gasket lightly and snap each metal hook into its slot around the door.
Schritt 6 Unscrew the light cover
Locate the oven light inside the cavity and grasp the glass cover.
Twist the cover counter-clockwise to loosen it; some models pull straight out.
If it is stuck, wrap a cloth around the cover and turn it gently with water-pump pliers.
Schritt 8 Fit the high-temperature oven bulb
Insert a high-temperature oven bulb rated for about 350 °C into the socket.
Tighten the bulb by hand until snug.
Schritt 9 Refit the glass cover and test
Thread the glass cover back onto the lamp housing until it seats firmly.
With the new gasket in place and the high-temperature bulb shining, your oven is sealed, lit and ready for many more reliable bakes.
