Zum Hauptinhalt wechseln
How to replace the door knob
Was du brauchst
  1. How to replace the door knob, Remove the screw holding the handle: Schritt 1, Bild 1 von 1
    • It is advisable to work with two people, one holding the outer handle on the outside and the other unloading the screw on the other side.
    • Remove the two screws.
    Frag FixBot
    Kommentar hinzufügen
  2. How to replace the door knob, Remove the handle: Schritt 2, Bild 1 von 1
    • Use pry bar carefully pry around, you can remove both sides of the door handle.
    • There is usually a plastic washer between the handle and the door, taking care not to damage it.
    • There will be a metal square shaft connected between the handle. Be careful not to lose it when removing the inside handle because the shaft is inside and outside.
    Frag FixBot
  3. How to replace the door knob, Pay attention to the square shaft: Schritt 3, Bild 1 von 1
    • Pay attention to the installation direction of this square shaft. Do not knock it off when removing the handle.
    Frag FixBot
Abschluss
Reversing the steps to know hot to install the know. It's easier than your thought , isn't it?
6 weitere Personen haben diese Anleitung absolviert.
zh en
100%
Hier starten ›
Z.Heng
3.878 Reputation
3 Anleitungen geschrieben
1 Kommentar zur Anleitung
图文并茂,生动形象,谢谢你的分享!
Conti - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 60
Insgesamt: 2,387
