Zum Hauptinhalt wechseln
How to replace the drive belt in your food processor
Was du brauchst
    • Unplug the food processor from the wall outlet.
    • Remove the bowl, blades, and any other accessories.
    • Set the loose parts aside to prevent damage or loss.
    • Insert a flat screwdriver under a rubber foot on the base.
    • Lever the foot out to reveal the hidden screw below.
    • Repeat for every foot that hides a screw hole.
    • Select screwdrivers that match the actual screw heads used on your model.
    • Unscrew all exposed screws and set them aside safely.
    • Lift the bottom cover off the housing to access the drive area.
    • Keep the screws and feet together so nothing is misplaced during reassembly.
    • Check whether the belt is torn, overstretched, or merely slipped off a pulley.
    • Heavy dough loads can push a healthy belt off its pulleys without tearing it.
    • Take the old belt to a shop that specializes in belts to obtain an identical replacement.
    • Match the new belt by overall length, tooth pitch, and tooth thickness.
    • Use the printed markings on the old belt to help the vendor supply the correct type.
    • Locate the four screws that secure the motor to its mounting plate.
    • Loosen each screw just enough for the motor to slide on its slots.
    • Support the motor so its weight does not strain the loose screws.
    • Add a few drops of machine oil to the lower motor shaft bushing.
    • Keep oil away from the pulley teeth to avoid belt slippage.
    • Loop the belt over the large drive pulley first.
    • Slip the belt onto the motor pulley.
    • Pull the motor away until the belt deflects about 3 to 5 mm under firm thumb pressure.
    • Hold the motor in position and tighten two opposite mount screws.
    • Re-check belt flex, then tighten the remaining mount screws fully.
    • Place the bottom cover back onto the housing.
    • Insert and tighten all cover screws securely.
    • Press the cleaned rubber feet back into their recesses until flush.
    • Reconnect power and run the motor briefly with no load to verify smooth, quiet operation.
    • Confirm that the belt stays centred on the pulleys without walking off.
    • Unplug the appliance before continuing to further work.
    • Remove the single screw securing the upper gearbox cover.
    • Lift the cover carefully, protecting any scale or sensor wiring inside.
    • Undo the three small screws that hold the gearbox plate in place.
    • Lift the gearbox plate along with its bushing and washers.
    • Spread industrial grease on the metal bushing and plastic gear teeth while rotating the gear by hand.
    • Apply grease to the shaft and the bushing inside the cover.
    • Use grease formulated for plastic gears to prevent chemical damage.
    • Return the washers to their original order on the shaft.
    • Seat the gearbox plate and insert all three screws finger-tight.
    • Tighten the screws in an alternating pattern so the plate sits evenly.
    • Re-fit the outer cover and secure its screw.
    • Photograph each disassembly stage to help identify screw positions during reassembly.
Abschluss
A correctly tensioned belt and fresh lubrication can bring even decades-old food processors back to full performance. Repeat lubrication and belt checks whenever the machine starts to slip or sound dry to keep it working like the first day.
Ula Gantar
16.474 Reputation
81 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 28
