Zum Hauptinhalt wechseln
How to replace the temperature sensor in your stove
Was du brauchst
    • Pull the power cord from the mains before working on the appliance.
    • Slide the built-in oven out of the cabinet to expose the back panel.
    • Remove every black screw securing the rear housing panels.
    • Beware of sharp sheet-metal edges that can cut skin.
    • Unplug the temperature sensor connector located on the back wall.
    • Remove one sensor retaining screw completely and loosen the other slightly.
    • Pull the sensor straight out of the oven cavity.
    • Insert the new sensor through the opening until its eyelet seats flush.
    • Tighten both retaining screws to secure the sensor.
    • Reconnect the sensor plug to the wiring harness.
    • Reinstall the rear panels with their screws.
    • Push the oven back into the cabinet in its original position.
    • Pull off the temperature control knob on the freestanding stove.
    • Take a photo of the shaft so the flat side faces the same way during reassembly.
    • Unscrew and remove the thermostat from the control panel.
    • Undo the screws on both sides that hold the cooktop.
    • Lift the cooktop slightly and support it to gain access without disconnecting wiring.
    • Inside the oven, loosen the screw securing the sensor bulb and withdraw it.
    • Carefully guide the capillary tube out along its original path.
    • Do not bend or kink the tube because it can crack.
    • Photograph the capillary connection at the thermostat.
    • Disconnect the tube and remove the old thermostat from the stove.
    • Lightly attach the new thermostat to the control panel.
    • Route the capillary tube gently to the oven cavity following the original path.
    • Seat the sensor bulb and tighten its retaining screw.
    • Fully tighten the thermostat mounting screws when alignment is correct.
    • Lower the cooktop and reinstall its side screws.
    • Push the control knob back onto the thermostat shaft in the recorded orientation.
    • Plug the stove back in and test that the oven heats and regulates properly.
    • If temperature control is still incorrect, recheck all connections and routing.
Abschluss
With a new temperature sensor fitted, your oven should now reach and hold the set temperature, ending under- or over-baked meals. Always unplug the appliance before future work, and treat sharp panels and fragile capillary tubes with care to keep both you and the stove in good shape.
Ula Gantar
16.609 Reputation
81 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 20
Letzte 30 Tage: 56
Insgesamt: 126
