Einleitung
Diese Anleitung zeigt dir, wie man den Chip für die Touch-ID vom Homebutton erneuert. Dies benötigt Kenntnisse im SMD Löten und wird eine komplette Funktion des Buttons nicht erneuern können.
Diese Anleitung ist sehr schwierig und erfordert spezielles Werkzeug.
Was du brauchst
In dieser Anleitung wird gezeigt, wie der Homebutton eines iPhone 7 repariert wird. Für weitere Informationen zur iPhone Reparatur schaue dir meine anderen Anleitungen an.
Um dein Gerät wieder zusammenzusetzen, befolge die Anleitung in umgekehrter Reihenfolge.
18 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
11 Kommentare
Do you have clear instructions and tools how to do it
So do you need to move the chip to replace the home button?
You need to reball or replace the chip to repair Touch ID.
If the home button or its flex cable is broken then it's completely shot, short of taking it to an Apple store for a replacement.
On the other hand, it could also be caused by the home button's extension flex cable running through the back of the lcd, and/or a damaged camera/speaker flex cable on top. So make sure to check all those out carefully before resorting to the Apple store.
After reading through a lot of suggestions, here's one which sounded interesting to me. Low and behold, this solution has actually worked!! I have removed that single screw completely, restarted the phone, and the home button started working perfectly.
05/31/2017 by screensaviors
I loosened the screw behind the center of the home button (holding it to the metal bracket), and it magically works now. This may not fix a lot of them, but it worked for me. I was just tightening that screw snug, but must have been too snug.
Very good points, it will certainly help people to resolve some of their problems, thanks for sharing your experience!
