Was du brauchst
On the side of the cartridge is a small electronic contact card with 4 contacts.
For those who are interested in transposing on other models, at the back of the contact card point is a EEPROM BR24L01A-W type memory.
The EDPROM can be reprogrammed thanks to an Arduino UNO card, for instance.
Prepare an Arduino UNO card with the following pins:
Pin 1 (SCL) connected to A5
Pin 2 (SDA) connected to A4
Pin 3 (5V) connected to the 5V port on the Arduino card
Pin 4 (GND) connected to GND on the Arduino card.
Download the ICI program file
Start Arduino and open the .ino file
Upload the program to the Arduino Uno board
Launch the serial monitor via the button at the top right
Make contact on the cartridge card. The 4 contacts need to work well at the same time
Follow the instructions to reprogram the memory according to the correct color (Black, Cyan, Magenta, Yellow)
By reinstalling the cartridge in the printer, it identifies it as 100% full!
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
100%
Hier starten ›
