Zum Hauptinhalt wechseln
How to resolve NO SIM problem / SIM card problem iPhone 6
Was du brauchst
    • This Tutorial will show you how to fix the No SIM Card hardware problem. Follow the guide to restore your iPhone 6 to get SIM Cards to work.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Sander
37.409 Reputation
202 Anleitungen geschrieben
3 Kommentare
i actually found a solution for this error you can follow Solution No. 1 provided with this website works for me
https://www.errorsolutions.tech/error/ip...
very informative and has a picture on it easy.
you can also try this, perform Network reset also sort out this issue.
Abigail Terry - Antwort
Where do I get new IC?
Maruti Patil - Antwort
The best way is to get it from the other motherboard.
Alex Sander -
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 33
Letzten 30 Tage: 158
Insgesamt: 25,039
