Zum Hauptinhalt wechseln
How to restore a shrunken sweater
Was du brauchst
  1. How to restore a shrunken sweater, How to restore a shrunken sweater: Schritt 1, Bild 1 von 1
    • Add 2/3 full of water into the washbasin.
    • Add 20 ml of Baby Shampoo into the washbasin.
    • The volume of water needed depends on the size of the sweater. The larger the sweater, the more water needed.
  2. How to restore a shrunken sweater: Schritt 2, Bild 1 von 1
    • Soak the sweater into the washbasin with soapy water for 15 mins.
  3. How to restore a shrunken sweater: Schritt 3, Bild 1 von 3 How to restore a shrunken sweater: Schritt 3, Bild 2 von 3 How to restore a shrunken sweater: Schritt 3, Bild 3 von 3
    • Take out the sweater from the washbasin with soapy water.
    • Remove the sweater to the bucket filled with fresh warm water.
    • Rinse the sweater thoroughly.
  4. How to restore a shrunken sweater: Schritt 4, Bild 1 von 1
    • Take out the sweater from the bucket.
    • Wring the clothes gently to get excessive water out.
  5. How to restore a shrunken sweater: Schritt 5, Bild 1 von 1
    • Place the sweater flat in the center of the bath towel.
  6. How to restore a shrunken sweater: Schritt 6, Bild 1 von 3 How to restore a shrunken sweater: Schritt 6, Bild 2 von 3 How to restore a shrunken sweater: Schritt 6, Bild 3 von 3
    • Roll while wringing the towel together with the sweater in order to dry the sweater.
    • Redo the process for a couple times until the sweater is dry to the touch.
    • Unfold the towel and take out the sweater
    • Spread out the sweater flat and let it dry.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Zhou Zhou
148 Reputation
1 Anleitung geschrieben
UC Davis, Team S2-G8, Bender Fall 2018 Mitglied von UC Davis, Team S2-G8, Bender Fall 2018
UCD-BENDER-F18S2G8
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 432
