Zum Hauptinhalt wechseln
How to tighten the Razor A handlebar clamp
    1. How to tighten the Razor A handlebar clamp, How to tighten the Razor A handlebar clamp: Schritt 1, Bild 1 von 1
      • Locate the T-tube clamp. It is in the middle of the steering column.
      Frag FixBot
      Kommentar hinzufügen
    2. How to tighten the Razor A handlebar clamp: Schritt 2, Bild 1 von 2 How to tighten the Razor A handlebar clamp: Schritt 2, Bild 2 von 2
      • Open the clamp by pulling the lever away from the scooter.
      Frag FixBot
    3. How to tighten the Razor A handlebar clamp: Schritt 3, Bild 1 von 2 How to tighten the Razor A handlebar clamp: Schritt 3, Bild 2 von 2
      • Locate the screw on the side of clamp.
      • Turn the screw on the side of the clamp by hand in a clockwise direction.
      • Attempt to close the clamp. If the lever is too tight to close, loosen the screw slightly and try again.
      • The T-tube should now be locked in place. If it continues to fall down, repeat the instructions in this guide.
      Frag FixBot
Ziellinie
Jordyn
565 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 9-13, Amido Fall 2012 Mitglied von Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Mitglieder
40 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 69
Insgesamt: 4,532
