Zum Hauptinhalt wechseln
How to unpair a Mitsubishi MMCS NR-242 Map SD Card
Was du brauchst
  1. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Identify your Revision: Schritt 1, Bild 1 von 1
    • You can find the Version Number of your MMCS printed on the top right corner of the unit.
    • You need either a Version W-11 or W-12. In this case the Version Number is W-12, so we can proceed.
  2. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Download the Unlock Binary: Schritt 2, Bild 1 von 1
    • You can download the Binary at this site.
    • Download the Binary.
    • Extract the NK.BIN file from the W12_MAP_UNLOCKER.rar archive using 7-Zip.
  3. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Move the File: Schritt 3, Bild 1 von 1
    • The SD card needs to be formatted to FAT32. If it’s not already formatted to FAT32 and you don’t know how to do it, you can take a look at this guide.
    • Copy the NK.BIN file to the root directory of the SD Card.
  4. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Flip up the Display: Schritt 4, Bild 1 von 2 How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Flip up the Display: Schritt 4, Bild 2 von 2
    • Press the OPEN-Button.
    • Press the Monitor OPEN-Button on the screen.
  5. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Swap the SD Cards: Schritt 5, Bild 1 von 2 How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Swap the SD Cards: Schritt 5, Bild 2 von 2
    • Remove the SD Cards from both the MAP and USER-Slots.
    • Insert the new SD Card into the USER-Slot.
    • Close the display by pressing the Open-Button again.
  6. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Reboot the Unit: Schritt 6, Bild 1 von 1
    • Long press both the NAVI MENU and AUDIO-Buttons to reboot into unlocker mode.
  7. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Insert the paired SD Card: Schritt 7, Bild 1 von 1
    • Open the display again by following the instructions in Step 4
    • Insert the paired SD Card into the MAP-Slot.
    • Wait 5-10 Seconds for the unpairing process to be completed before removing it again.
  8. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Return the SD Cards: Schritt 8, Bild 1 von 1
    • Return the SD Cards you removed in Step 5 back to their respective Slots.
  9. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Exit the Unlocking Mode: Schritt 9, Bild 1 von 1
    • Long press both the NAVI MENU and AUDIO-Buttons again to reboot back into standard mode.
Abschluss
Drive safe!
Sebastian
28.482 Reputation
71 Anleitungen geschrieben
German Translators Mitglied von German Translators
Community
35 Mitglieder
1.220 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 99
Insgesamt: 1,587
