Zum Hauptinhalt wechseln
Einleitung
Internet Recovery has a number of useful applications. This guide will show you how to use Internet Recovery to install a fresh copy of macOS to a blank or corrupted SSD.
Internet Recovery is only available on Apple computers made after 2009. If your computer was released in 2010 or 2011, you may need to update to the latest version of macOS to enable Internet Recovery.
Werkzeuge
Keine Werkzeuge angegeben.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Shut down the computer.
    • Shut down the computer.
  2. Once the computer is completely shut down, press the power button, then immediately press and hold the key combination cmd + option + R.
    • Once the computer is completely shut down, press the power button, then immediately press and hold the key combination cmd + option + R.
  3. When the spinning globe animation appears, you can release the keys. The globe will spin while Internet Recovery starts up. If you are not using a wired internet connection, a choose network prompt will appear. Use this menu to connect the computer to a WiFi network.
    • When the spinning globe animation appears, you can release the keys.
    • The globe will spin while Internet Recovery starts up. If you are not using a wired internet connection, a choose network prompt will appear. Use this menu to connect the computer to a WiFi network.
  4. Once a network connection has been established, a progress bar will appear underneath the spinning globe.
    • Once a network connection has been established, a progress bar will appear underneath the spinning globe.
  5. When Internet Recovery has loaded, you will see the macOS recovery screen.
    • When Internet Recovery has loaded, you will see the macOS recovery screen.
  6. Before you can install macOS to the new drive, you'll need to format the drive so the installer can recognize it. Open Disk Utility from the recovery menu, select your drive, and click the Erase button toward the top of the Disk Utility window. Make up a name for your drive, and make sure the format is set to Mac OS Extended (Journaled) or APFS.
    • Before you can install macOS to the new drive, you'll need to format the drive so the installer can recognize it.
    • Open Disk Utility from the recovery menu, select your drive, and click the Erase button toward the top of the Disk Utility window.
    • Make up a name for your drive, and make sure the format is set to Mac OS Extended (Journaled) or APFS.
    • If you don't see your drive listed in the Disk Utility menu, select Show All Devices from the View section of the menu bar.
    • Once the new drive is formatted, press Command + Q to exit Disk Utility and return to the recovery menu.
  7. Back at the recovery menu, select Install macOS .
    • Back at the recovery menu, select Install macOS .
  8. Follow the prompts to install macOS, selecting the newly formatted disk as the target for the installation. Follow the prompts to install macOS, selecting the newly formatted disk as the target for the installation.
    • Follow the prompts to install macOS, selecting the newly formatted disk as the target for the installation.
Abschluss
Your computer may restart several times during the installation of macOS. Once the installation is complete, you can use Migration Assistant to transfer data from your old drive to the new one.
13 weitere Nutzer haben diese Anleitung absolviert.
Taylor Dixon
21.803 Reputation
72 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
107 Mitglieder
9.591 Anleitungen geschrieben
Perfect, it is soooooo easy
Cheers
Michael
Michael Clark - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 51
Letzten 7 Tage: 279
Letzten 30 Tage: 1,304
Insgesamt: 7,113
