Zum Hauptinhalt wechseln
How to use John the Ripper in Kali Linux
Was du brauchst
    • Start your computer and boot into Kali Linux
    • If you don't yet have a Kali Linux machine, follow this guide to install the OS onto a Virtual Machine
    • Once the operating system has fully loaded, open the terminal interface.
    Frag FixBot
    Kommentar hinzufügen
    • Identify the target file that contains the hashed passwords that you want to crack.
    • Use the Terminal interface to navigate to the directory where your target file is located.
    Frag FixBot
    • John the Ripper requires that the hashed passwords be in a specific format.
    • If the target file contains unsalted MD5 hashes, then you can proceed to the next step. Otherwise you will need to convert the hashes to a compatible format.
    Frag FixBot
    • In the terminal, enter the following command to initiate the John the Ripper program.
    • John [path/to/target/file]
    • John the Ripper will start processing the password hashes using the default settings.
    Frag FixBot
    • John the Ripper will display its progress and estimated time remaining.
    • Once John the Ripper has finished processing, it will display the cracked passwords (if successful) or indicate the inability to crack certain passwords.
    Frag FixBot
    • Examine the results displayed by John the Ripper in the Terminal.
    • Cracked passwords will be displayed alongside their corresponding hashes.
    • Use the obtained passwords responsibly and ensure that they conform to any applicable laws or policies.
    Frag FixBot
Abschluss
Congratulations, you have successfully used John the Ripper with Kali Linux to audit and recover passwords. Remember to exercise caution and ethical considerations when using password-cracking tools.
The most important thing you should take away from this guide is to remember to use this information responsibly. Obtaining unauthorized access to another's computer system or systems is illegal under the Computer Fraud & Abuse Act.
Please use the knowledge gained from this guide responsibly.
4 weitere Personen haben diese Anleitung absolviert.
iFanatics Mitglied von iFanatics
Community
69 Mitglieder
237 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 34
Letzte 30 Tage: 231
Insgesamt: 20,089
