Einleitung
Use this guide to keep your cooktop and oven working safely and efficiently. Correct cookware, the right settings and regular cleaning will save energy, improve cooking results and extend the life of your appliance.
Was du brauchst
Schritt 1 Identify your cooktop type
Survey the appliance to decide whether it has solid electric plates, gas burners, glass-ceramic zones or induction coils.
Schritt 2 Select cookware for gas burners
Choose pots and pans with a thick, stable base to prevent warping in the intense flame.
Schritt 3 Select cookware for glass-ceramic or solid plates
Use cookware with a perfectly flat bottom so it maintains full contact with the glass-ceramic surface.
Schritt 4 Select cookware for induction hobs
Carry a small magnet to the store and verify that it sticks firmly to the pan base before buying.
Only cookware with a ferromagnetic bottom will heat on an induction hob.
Schritt 5 Remove and clean gas burner parts
Lift off the burner caps and heads and soak them in hot water mixed with laundry detergent for two to three hours.
Scrub the soaked parts with an abrasive sponge to remove burnt deposits.
Schritt 6 Clean a glass-ceramic hob
Spread a dedicated creamy cleaner over the cool surface.
Hold a purpose-made scraper flat and lift off baked-on spots without scratching the glass.
Wipe the hob with a non-abrasive sponge or soft cloth, then buff it dry.
Schritt 7 Clean an induction hob
Because the surface stays relatively cool, wipe it with a mild cleaner and a soft cloth as soon as cooking is finished.
Schritt 8 Identify your oven type
Conventional ovens use only top and bottom heating elements and suit slow roasts, bread dough and single-tray baking.
Schritt 9 Recognize additional oven features
Many modern ovens offer a meat probe, delayed start, automatic programs and steam injection for precise baking control.
Schritt 10 Choose the right baking tray
Measure the oven’s width and depth before buying trays to ensure they fit easily on the runners.
Schritt 11 Prepare food before baking
Preheat the oven unless the recipe explicitly states otherwise.
Schritt 13 Set an appropriate temperature
Use 150–200 °C for most baking, 120–130 °C for slow cooking, and up to 220 °C for quick grilling.
Schritt 14 Understand common function symbols
Bottom element with fan browns pizza or pastries evenly and crisps the base.
Fan-only mode is ideal for baking several trays at once.
Top and bottom elements without fan are best for bread and general single-tray baking.
Bottom element alone keeps dishes warm on the lowest rack.
Schritt 16 Clean enamel-lined ovens
Remove racks and soak them in hot water with washing powder for two to three hours.
Scrub racks and cavity with a wire-wool pad to lift residue without damaging the enamel.
Schritt 17 Maintain catalytic liners
Catalytic panels feel rough; at high heat they oxidise splattered grease automatically.
Schritt 18 Run a pyrolytic self-clean cycle
When the oven cools, sweep out the ash and wipe the cavity with a damp cloth.
Schritt 19 Steam-clean a standard oven
Place a tray of water with a lemon slice on the lowest shelf, set 120–130 °C and let it run for 40 minutes.
Switch the oven off and keep the door closed for about two hours so the steam softens residue.
Wipe the interior clean with a cloth once the oven is cool.
Regular care, the correct cookware and thoughtful use of functions will keep your stove and oven reliable for many years. Treat the appliance with respect, clean it promptly and always follow the safety cautions outlined above.
