Was du brauchst
Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
Lift the battery from the middle and then pivot it outward to remove it from the computer.
Remove the bezel by prying it away from the screen using the spudger.
Note: Some models may have two screws hidden behind round covers in the lower section of the bezel.
Remove the four 3mm PH1 Phillips head screws in each corner of the screen and do not care about outer screws.
Eine weitere Person hat diese Anleitung absolviert.
