Zum Hauptinhalt wechseln
Hp Pavilion dv6-2155dx Optical Drive Replacement
Was du brauchst
  1. Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: Schritt 1, Bild 1 von 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: Schritt 1, Bild 2 von 2
    • Flip the computer around to the back side.
    • Remove the three screws from the memory module cover.
    • Screws will not come out all the way.
    • All screws to loosen/removed in this guide will require a Phillips #01 screwdriver.
  2. Hp Pavilion dv6-2155dx Optical  Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the screw completely from the memory module panel to help release the Optical drive from the body of the computer.
    • The screw is 7mm long and head is 4mm wide.
  3. Hp Pavilion dv6-2155dx Optical  Drive Replacement: Schritt 3, Bild 1 von 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: Schritt 3, Bild 2 von 2
    • Locate the small hole next to the eject button.
    • Get a paper clip and insert in to the small hole until you hear a clicking sound and seeing the tray pop out.
    • Before removing the optical drive, be sure that there is nothing in the drive. Optical drives are fragile so handle with care.
  4. Hp Pavilion dv6-2155dx Optical  Drive Replacement: Schritt 4, Bild 1 von 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: Schritt 4, Bild 2 von 2
    • Gently pull the Optical drive out of the slot until the whole thing comes out.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 2-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G2
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 1,029
