Einleitung
Replacing the 8GB of ram in my HP zBook studio g3 mobile workstation to 16 GB
Was du brauchst
Remove the 4 screws holding down the dust filter
Remove the dust filter
Remove the 4 outer screws.
Remove the 2 inner screws holding the housing down.
Now lift the housing. This may require some force
Remove the old ram module by pushing these two tabs outwards. The module should swing up
Now pull the module out away from the holder
Orient the memory modules such that then notch in the connector lines up with the grove in the module
slide the module all the way into the holder such that the pins are in the connector
Push down on the module to lock it in the holders
3 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Would be really good to have one for the SSD
I am thinking of expanding the storage on this model. If I get around to it I’ll post a guide
jort -
For retail stores like me this is very helpful. I can send to customers so they can upgrade themselves. Thanks for sharing
My Website: Laptop Workstation cũ Tphcm
