Was du brauchst
With the help of a heat source and a cross-head screwdriver, remove the 9 screws along the sides of the phone . One screw is covered by an adhesive label.
Remove the shortest screw that secures the center of the body, located next to the SIM card.
With the help of thin tool, unhinge the joints between the outer cover and the internal frame of the display.
Remove the outer cover.
If the glass is broken, apply Scotch tape to avoid further damage.
Use a heat source to heat the edge of the glass.
With a thin tool
Insert translation here
Once the touch screen has been removed, proceed with the cleaning of the remaining double-sided adhesive tape
Apply the new double-sided adhesive and the new touch screen
To reassemble the device follow all the steps in reverse order
To reassemble the device, follow these instructions in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
