Einleitung
If your ear speaker on your Huawei Ascend G610 is broken, follow this guide.
With a cross-head screwdriver remove 9 side screws that secure the back case.
Remove the adhesive to find the underlying screw.
Remove the shortest central screw near the SIM card slot.
With the help of a thin tool, pry open the back case.
With the help of a heat source to loosen the adhesive, remove the broken ear speaker and replace it with the new one.
To reassemble the device, follow these instructions in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
