Einleitung
Follow this guide if your camera needs to replace the rear camera
Remove the 9 side screws with a Phillips screwdriver, beware a blanket with a sticker
The 10th screw that is shorter is centrally located near the Sim card slot
With the help of a thin instrument, unhook the central structure anchored to the external profile
Remove the central structure
Unhook the camera connector indicated by the red arrow and replace with the new one
To reassemble the device, follow these instructions in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
irlanda hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
