Einleitung
Follow this repair guide if you have problems with the brightness sensor in your device
With the help of a Phillips screwdriver, remove the 9 side screws, one is located under the adhesive
With the help of a thin tool, pry up the side joints to remove the central body
With the help of a thin tool, uncouple the mother board interlocked on the plastic hooks
With the help of a heat source of the tweezers remove proximity and brightness sensor by replacing it with a new one
To reassemble the device, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
100%
irlanda hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
