Einleitung
Volume and power buttons ribbon cable replacement
with the help of a Phillips screwdriver remove the nine side screws, one is under the adhesive that must be removed
Remove the 10th screw, it is shorter in the middle near the Sim card slot
With the help of a thin tool, pry laterally on the joints and remove the central body
With the help of a heat source, remove the audio and power button ribbon cable
To reassemble your device follow these instructions in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
