Was du brauchst
Disconnect all connected devices (such as headphones and USB chargers).
Turn the device off.
Turn the device around.
On the same side as the powerbutton is a little notch. Using it you will have to carefully remove the back cover.
Use a small prying tool if you can't do this with your fingers.
Now you can remove the battery, that has to be pryed off in the marked location.
Follow the steps in reverse order to reassemble your device.
100%
Alex Niculescu hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
