Einleitung
It is a fairly simple and straightforward guide. Just be careful when you're removing the back cover. It can break easily.
Flip the device over so that the back of the phone is facing you and the screen is against your palm.
Locate the slit at the bottom of the back cover.
Using your fingernail, lift up on the back cover to expose the battery.
Find the indented notch at the base of the battery.
Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
2 weitere Personen haben diese Anleitung absolviert.
