Einleitung
It is a straightforward guide showing the steps towards removing the front camera. Remember to be careful during the disassembling. The parts can break easily.
Was du brauchst
Flip the device over so that the back of the phone is facing you and the screen is against your palm.
Locate the slit at the bottom of the back cover.
Using your fingernail, lift up on the back cover to expose the battery.
Find the indented notch at the base of the battery.
Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
After removing the battery, remove the screws using a T6 screwdriver.
There are eleven screws that hold the middle cover to the rest of the phone.
The screw that is marked by the orange circle is covered by a white dot.
After all the screws are removed, use your fingers to remove the lower section of the middle cover.
Pull the lower section of the middle cover outward towards you, exposing the circuit board underneath.
Begin working your way around the sides of the cover plate, unsnapping it gently.
The middle cover is a thin piece of plastic with the external speaker inside of it.
The antenna is a thin white wire that connects to the circuit board in two locations.
Lift gently at each connector of the white wire to disconnect the antenna from the port.
Use a plastic spudger or your fingers to gently pry up the four flex cables from the main board.
Gently pry up near the small black clip with your fingers or a plastic spudger to detach the main board.
With the main board facing away from you, the front camera is on the top right corner.
There is a silver connector and a black flex cable attached to the front camera.
Using the small pliers, disconnect the front camera's flex cable from the main board.
Once the flex cable is disconnected, completely remove the front camera off the main board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
