Einleitung
This guide will show you how to replace the battery on your Huawei Ascend Y300. If your battery seems to drain quickly, or you can only use it when it's plugged into the charger, it's time for a battery replacement. The battery powers your device and once it loses power your phone won’t work or power on.
Before you begin, make sure your phone is off and unplugged from the charger.
Was du brauchst
First, you want to flip the phone screen facing down. To remove the rear cover located on the back of the phone, you must grip on the gap located at the bottom of the phone. Lastly, pull up!
In order to remove the battery, you must first locate the gap intended for removal above the battery. You will then push down using the tip of your finger while also pulling outward to remove the battery for replacement.
After the battery is removed, you must replace the battery using the new one. To insert the new battery you must align the connection between the battery and the device. Lastly, you will push the bottom of the new battery until it is sitting inside the intended station.
This will be your new source of power.
To reassemble your device, follow these instructions in reverse order. After you have inserted the new battery, simply, replace the back cover and began pushing down on the cover until it snaps into place.
10 weitere Personen haben diese Anleitung absolviert.
