Einleitung
Use this guide to replace the fingerprint scanner assembly on your device. This requires the use of a heat gun to weaken adhesive, be safety cautious when using these tools.
Was du brauchst
Insert the SIM Card Eject Tool into the SIM card tray hole.
Press the eject tool into the hole until the tray clicks open.
Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
Pry the screen off the back of the phone by pushing down on the opening tool.
Slide the opening tool or spudger along the bottom of the phone and around the edge.
Once three sides of the screen are detached, pry the phone apart using two hands.
Disconnect the fingerprint scanner cable attached to the motherboard using a spudger or your finger.
Apply heat around the finger print scanner assembly using a heat gun or hair dryer.
Separate the fingerprint scanner assembly from the back panel using a spudger.
Remove the finger print scanner from the device by lifting it with two fingers.
5 weitere Personen haben diese Anleitung absolviert.
