Einleitung
This guide will show how to replace the camera on a Huawei M750 smartphone.
Was du brauchst
Depress the top of the battery cover, and pull downwards towards the base of the phone.
Remove the battery by levering the battery out, using the cut just below the camera.
Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
Work the opening tool around the border of the camera and speaker cover, until it comes loose.
Using the opening tool, pry the back panel from the front panel.
Work your way around the phone until the panels separate evenly.
The camera's connection to the motherboard is shown here.
Using the tweezers, disconnect the port, shown here in the picture.
