Einleitung
Accessing the motherboard of the Huawei Mate 10 Pro is often an important step in solving hardware issues. Whether it is to access other parts of the device or to install a new motherboard, this guide will show the steps needed to safely remove it.
Was du brauchst
Insert a SIM opening tool in the hole on the left side and push it in.
Remove the SIM card tray.
Switch off your phone.
Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
In diesem Schritt verwendetes Werkzeug:Halberd Spudger$2.99
Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
Flip the back cover over to the side.
Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
Disconnect the fingerprint sensor cable with a spudger.
Unscrew screws on black cover and remove using tweezers to leverage.
Separate camera assembly by popping it out, if only the motherboard is needed.
