Einleitung
Unlike most tablets, the Huawei MediaPad M2 10.0 has a display assembly that is easy to remove, a big positive when looking at repair. The battery is incredibly difficult to remove, however, giving the tablet a 7 out of 10 on the repairability scale.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Simple plastic clips make opening easy.
The display cable has enough slack to lay the display aside to work on the interior.
Display assembly carries: display interconnect cable, home button/fingerprint reader and cable, and its bracket.
Home button/fingerprint reader is easily removed and replaced.
The battery is glued to the rear case by very strong adhesive.
Heat, adhesive removal fluid, and much prying, the battery is removed.
Frustrating that an inevitable repair/replacement would be this hard, but at least it isn't blocking other components' replacement.
The bracket over the speaker and button/headphone jack cable has two different kinds of screws, Torx and Phillips, making removal obnoxious.
Removable in parallel with the battery are: lower speaker, speaker/antennas, brackets, and microphone bumper.
SIM tray can be removed while the device is sealed, obviously.
The final components out of the rear case are fairly modular:
SIM reader and vibrator assembly
Headphone jack and button cable assembly
Front and rear facing cameras
Motherboard, unfortunately has a soldered-on charging port. That means a more expensive repair for a common failure point.
The Huawei MediaPad M2 earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
The display is easily removed from the simple clips holding it to the body, simplifying repairs.
Most components are modular and not overly complex.
The battery is extremely difficult to remove, even with heat and prying.
The charging port is soldered to the motherboard, making replacement of this high-use component expensive.
Manufacturer does not provide user-accessible repair documentation.
7 weitere Nutzer haben diese Anleitung absolviert.
3 Kommentare
Does the display assembly have any glue?
Where does one start from to pry open the screen assembly and is the MediaPad m3 similar to this?
Will be much obliged if you could throw some light on it.
Deutsch:
Gute Anleitung! Habe bereits bei dem Gerät die USB Buchse erneuert - manuell entlötet und eine neue Buchse eingelötet. Sehr angenehm zu reparieren!
English version:
Great instruction manual! I replaced a broken USB port by handsoldering! Very nice to repair!
