Zum Hauptinhalt wechseln
Huawei Mediapad t1 7.0" Touchscreen Replacement
  1. Huawei Mediapad t1 7.0" Touchscreen  Replacement, Touch Screen: Schritt 1, Bild 1 von 1
    • Open the SD slot and remove the screw hidden under the sticker.
  2. Huawei Mediapad t1 7.0" Touchscreen  Replacement: Schritt 2, Bild 1 von 3 Huawei Mediapad t1 7.0" Touchscreen  Replacement: Schritt 2, Bild 2 von 3 Huawei Mediapad t1 7.0" Touchscreen  Replacement: Schritt 2, Bild 3 von 3
    • Use an opening pick to disengage the clips securing the back cover.
  3. Huawei Mediapad t1 7.0" Touchscreen  Replacement: Schritt 3, Bild 1 von 3 Huawei Mediapad t1 7.0" Touchscreen  Replacement: Schritt 3, Bild 2 von 3 Huawei Mediapad t1 7.0" Touchscreen  Replacement: Schritt 3, Bild 3 von 3
    • Carefully swing up the display assembly, still connected by the touchscreen and display ribbon cables.
    • Disconnect the touchscreen connector.
    • Disconnect the display connector.
  4. Huawei Mediapad t1 7.0" Touchscreen  Replacement: Schritt 4, Bild 1 von 3 Huawei Mediapad t1 7.0" Touchscreen  Replacement: Schritt 4, Bild 2 von 3 Huawei Mediapad t1 7.0" Touchscreen  Replacement: Schritt 4, Bild 3 von 3
    • Remove the 6 screws that secure the 2 metal stripes holding the display.
    • Remove the display.
  5. Huawei Mediapad t1 7.0" Touchscreen  Replacement: Schritt 5, Bild 1 von 3 Huawei Mediapad t1 7.0" Touchscreen  Replacement: Schritt 5, Bild 2 von 3 Huawei Mediapad t1 7.0" Touchscreen  Replacement: Schritt 5, Bild 3 von 3
    • Apply heat on the panel edges. Use an opening pick to separate the glass panel from the plastic frame.
  6. Huawei Mediapad t1 7.0" Touchscreen  Replacement: Schritt 6, Bild 1 von 2 Huawei Mediapad t1 7.0" Touchscreen  Replacement: Schritt 6, Bild 2 von 2
    • Remove any remaining adhesive and piece of glass to allow adhesive and glass panel replacement.
Abschluss
To assemble the device, follow these instructions in reverse order.
25 weitere Personen haben diese Anleitung absolviert.
it en
100%
Hier starten ›
Smilzo
12.137 Reputation
39 Anleitungen geschrieben
4 Kommentare zur Anleitung
Not very clear unlike other guides I have followed….
Tracey Homeward - Antwort
Ottimo video,
ti chiedo un consiglio, stavo cambiando il display al mio Huawei T1 A21 quando il connettore sul circuito stampato che collega il touch-screen si è danneggiato.
E’ un connettore particolare 25 pin + 28 e non riesco a trovarlo, sai dirmi come reperirlo?
grazie
Antonio
Antonio Durighello - Antwort
Ciao,non saprei dirti dove trovarlo, io farei delle
ricerche online.
Nel caso che lo trovi è comunque un’intervento abbastanza complesso di saldatura ma visto che comunque è rotto tentare non nuoce.
attrezzati bene.
buona fortuna
Smilzo - Antwort
ricerche online.
attrezzati bene.
buona fortuna
Smilzo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 64
Insgesamt: 20,747
