Einleitung
Use this guide to replace the back cover of your Huawei P10 smartphone.
Was du brauchst
Switch off your phone.
Remove the two Pentalobe P2 screws at the bottom.
Remove the SIM card tray.
Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
Carefully pry the display with its parts out of the case.
After you pried out the bottom end, use the opening tool to open the clamps on both sides.
Swing open the phone backwards.
Use a spudger to disconnect the power- and volume button flex cable.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
