Einleitung
Use this guide to replace the battery in your Huawei P10 smartphone.
Was du brauchst
Switch off your phone.
Remove the two Pentalobe P2 screws at the bottom.
Remove the SIM card tray.
Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
Carefully pry the display with its parts out of the case.
After you pried out the bottom end, use the opening tool to open the clamps on both sides.
Swing open the phone backwards.
Use a spudger to disconnect the power- and volume button flex cable.
Use a spudger to disconnect the battery, the interconnect and the display flex cable.
Peel out the adhesive strip which is placed beneath the battery by steadily pulling at the tab in a flat angle.
Use an iOpener to loosen the remaining adhesive.
In diesem Schritt verwendetes Werkzeug:Tesa 61395 Tape$5.99
Insert an opening pick or spudger beneath the battery and carefully pry it out.
Remove the battery.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
75 weitere Nutzer:innen haben diese Anleitung absolviert.
16 Kommentare
Thanks for posting this this give me new ideas.
Facile comme bonjour. Les outils que j'avais reçu avec la batterie étaient de piètre qualité, j'ai donc utilisé des mini-spatules utilisées pour lisser les joints en silicone, c'est pile la consistance voulue pour décoller le dos et la batterie, ni trop ferme ni trop souple.
Easy fix, thanks a lot.
Eccellente guida peccato che una volta montata la nuova batteria in cellulare si sente che si accende la il display rimane buio, controllato connessioni ma sono tutte ok e display sempre spento, cosa può essere?
Adriano
