Zum Hauptinhalt wechseln
Huawei P10 Lite Battery Disconnection
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Huawei P10 Lite Battery Disconnection, Back cover: Schritt 1, Bild 1 von 3 Huawei P10 Lite Battery Disconnection, Back cover: Schritt 1, Bild 2 von 3 Huawei P10 Lite Battery Disconnection, Back cover: Schritt 1, Bild 3 von 3
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Battery Disconnection: Schritt 2, Bild 1 von 3 Huawei P10 Lite Battery Disconnection: Schritt 2, Bild 2 von 3 Huawei P10 Lite Battery Disconnection: Schritt 2, Bild 3 von 3
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Battery Disconnection: Schritt 3, Bild 1 von 2 Huawei P10 Lite Battery Disconnection: Schritt 3, Bild 2 von 2
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Battery Disconnection: Schritt 4, Bild 1 von 2 Huawei P10 Lite Battery Disconnection: Schritt 4, Bild 2 von 2
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Huawei P10 Lite Battery Disconnection, Battery Disconnection: Schritt 5, Bild 1 von 3 Huawei P10 Lite Battery Disconnection, Battery Disconnection: Schritt 5, Bild 2 von 3 Huawei P10 Lite Battery Disconnection, Battery Disconnection: Schritt 5, Bild 3 von 3
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
Abschluss
Dominik Schnabelrauch
203.299 Reputation
682 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.817 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 158
