Einleitung
How to disassemble Huawei P30 Pro an fix stuck in boot-loop problem.
Einführungsvideo
Huawei P30 Pro boot loop solution
Warm up the device to soften the adhesive.
To separate the battery cover use plastic tools and a little isopropyl alcohol.
Remove the Phillips screws.
Remove the motherboard cover.
Disconnect the battery and the main flex cable.
Check the parts around the battery connector most probably damaged during previous repair.
Re-solder the resistors or solder new if someone missing or broken.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Other places mention these resistors as 2 kOhm, both. Which value is correct ?
