Was du brauchst
Apply a little heat around the base then, using a suction cup, lift the screen up sufficiently that you can place a pick between the screen and the case.
The adhesive is very light and the rear is plastic so it is unlikely to break.
As well as the adhesive around the outside of the screen, there is adhesive around the camera which will also need to be heated and separated from the body of the screen.
Remove the 10 Phillips #00 screws, including the one covered in a white piece of paper.
Use a spudger to lift up the battery connector (being careful not to damage the surrounding circuitry).
Peel the black plastic from the battery. The adhesive here should be very light.
Peel back tab 1 and 2 until they are no longer in contact with the battery
Peel back tab 3 and lift up.
Use a spudger to disconnect the screen connector from the motherboard and lift the cable from the adhesive.
Apply heat to the edge of the screen, and use a suction cup or blunt scalpel to help work a plastic pick under the screen.
Eine weitere Person hat diese Anleitung absolviert.
