Einleitung
Use this guide to remove and replace the display of a Huawei P8.
Was du brauchst
First switch off your phone.
Remove the trays for the SD card and the SIM card.
Remove the two Torx T2 screws located at the bottom next to the micro USB port.
Use an iSclack or a suction handle to separate the display unit from the rear panel.
Remove the two Phillips #00 that hold down the two metal clamps covering the front camera, the display and battery flex connectors.
Use a tweezer to remove the metal clamp covering the display and the battery flex connector.
Unplug the battery flex connector with a Spudger.
Remove the metal clamp covering the flex connector of the front camera.
Unplug the headphone jack and the front camera flex connectors.
Remove the front camera.
Unscrew the four Phillips #00 screws that hold down the motherboard of your Huawei P8.
Unplug the vibration motor flex connector.
Disconnect the antenna cable.
Unplug the display flex connector from the main board with a Spudger.
Disconnect and remove the antenna cable with a tweezer.
Use a spudger to disconnect the flex cable of the power and volume buttons.
Remove the liquid contact indicator that sits on top of the last screw holding down your main board.
Unscrew the Phillips #00 screw.
Lift up the main board with a spudger and remove it.
Remove the adhesive tape which is covering the display flex cable.
Loosen the adhesive around the mid frame with an iOpener.
When the glue is softened you can use a spudger to get behind the display through the camera bay and get between the frame and the display.
Insert an opening pick in the gap where you separated the display from the mid frame.
Insert just the tip of the opening pick and slide it along the right side to separate the display from the frame.
Insert another opening pick at the top of the phone and loosen the adhesive under the upper part of the display.
Insert just the tip of the opening pick and slide it along the left side of the phone to separate the display from the frame.
Loosen the adhesive under the bottom part of the display unit with the opening pick.
Flip the opening pick a little to separate the display from the mid frame.
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Is there any difference on screen frame between GRA-L09 and GRA-TL10??? The l09 is the single sim and the TL10 is the dual sim…
installing a new screen the first time, i was looking at darkness. then, taking it apart again and taking away the protective foil on the back of the screen, it just showed pink/purple colors and started heating up pretty bad around the charging connector. my idea would be a short circuit. any idea what is going wrong and can this still be saved?
