Zum Hauptinhalt wechseln
Einleitung
Use this guide to replace a damaged fingerprint sensor on your Huawei P8 Lite (2017) .
You’ll need replacement adhesive to reattach components when reassembling the device.
  1. Heat an iOpener and apply it to the rear glass for two minutes.
    • Heat an iOpener and apply it to the rear glass for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the P8 Lite—the display and internal battery are both susceptible to heat damage.
  2. Apply a suction cup to the rear glass, as close to the right edge as possible. If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Apply a suction cup to the rear glass, as close to the right edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Pull up on the suction up with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat to further soften the adhesive and try again.
    • Insert the tip of an opening pick into the gap between the rear glass and frame.
  3. Slide the tip of the opening pick to the bottom right corner to cut the adhesive. Leave it there to prevent the adhesive from resealing.
    • Slide the tip of the opening pick to the bottom right corner to cut the adhesive.
    • Leave it there to prevent the adhesive from resealing.
  4. Insert a second opening pick at the bottom right corner. Slide the tip of the opening pick to the top right corner to slice the adhesive.
    • Insert a second opening pick at the bottom right corner.
    • Slide the tip of the opening pick to the top right corner to slice the adhesive.
    • Leave the opening pick at its place to prevent the adhesive from resealing.
  5. Insert a third opening pick at the top right corner. Slide it to the top left corner to cut the adhesive.
    • Insert a third opening pick at the top right corner.
    • Slide it to the top left corner to cut the adhesive.
    • In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it.
  6. Insert a fourth opening pick at the top left corner. Do not insert the opening pick deeper than 1 cm (1/3rd of an inch) to avoid damage the fingerprint sensor cable.
    • Insert a fourth opening pick at the top left corner.
    • Do not insert the opening pick deeper than 1 cm (1/3rd of an inch) to avoid damage the fingerprint sensor cable.
    • Slide the tip of the opening pick to the bottom left corner to cut the adhesive.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
  7. Insert a fifth opening pick at the bottom left corner. Slide it to the bottom right corner to cut the remaining adhesive.
    • Insert a fifth opening pick at the bottom left corner.
    • Slide it to the bottom right corner to cut the remaining adhesive.
    • Try not to remove the rear glass yet! The fingerprint sensor is still connected to the motherboard.
  8. Open the P8 Lite by swinging the rear glass up from the left side, like the back cover of a book. Place the rear glass on the top of the battery. Avoid tensioning the display cable during this procedure.
    • Open the P8 Lite by swinging the rear glass up from the left side, like the back cover of a book.
    • Place the rear glass on the top of the battery.
    • Avoid tensioning the display cable during this procedure.
  9. Use a Phillips #00 screwdriver to remove the 2.9 mm screw.
    • Use a Phillips #00 screwdriver to remove the 2.9 mm screw.
  10. Use the tip of an opening pick to pry up and loosen the metal shield. Use the tip of an opening pick to pry up and loosen the metal shield.
    • Use the tip of an opening pick to pry up and loosen the metal shield.
  11. Use a pair of tweezers to remove the metal shield.
    • Use a pair of tweezers to remove the metal shield.
  12. Use a spudger to pry up and disconnect  the fingerprint sensor cable. Use a spudger to pry up and disconnect  the fingerprint sensor cable.
    • Use a spudger to pry up and disconnect the fingerprint sensor cable.
  13. Remove the rear glass.
    • Remove the rear glass.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  14. Use a pair of tweezers to peel off the yellow protective sticker from the fingerprint sensor connector. Use a pair of tweezers to peel off the yellow protective sticker from the fingerprint sensor connector. Use a pair of tweezers to peel off the yellow protective sticker from the fingerprint sensor connector.
    • Use a pair of tweezers to peel off the yellow protective sticker from the fingerprint sensor connector.
  15. Peel off the black sticker until the sensor is completely exposed. Peel off the black sticker until the sensor is completely exposed.
    • Peel off the black sticker until the sensor is completely exposed.
  16. Heat an iOpener and apply it to the rear glass  where the fingerprint sensor is located to loosen the adhesive underneath.
    • Heat an iOpener and apply it to the rear glass where the fingerprint sensor is located to loosen the adhesive underneath.
  17. Slide an opening pick underneath the top edge of the small board next to the fingerprint sensor. Use the opening pick to carefully loosen the adhesive underneath the fingerprint board. Slide the opening pick underneath the fingerprint sensor to cut the remaining adhesive holding it in place.
    • Slide an opening pick underneath the top edge of the small board next to the fingerprint sensor.
    • Use the opening pick to carefully loosen the adhesive underneath the fingerprint board.
    • Slide the opening pick underneath the fingerprint sensor to cut the remaining adhesive holding it in place.
  18. Remove the fingerprint sensor.
    • Remove the fingerprint sensor.
Abschluss
Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Compare your new rear glass to the original part. You may need to transfer the fingerprint sensor or remove adhesive backings from the new part before installing.
Adriana Zwink
14.578 Reputation
77 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
136 Mitglieder
15.992 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 51
