Zum Hauptinhalt wechseln
Huawei P8 Lite Battery Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Huawei P8 Lite Battery Replacement, Loudspeaker: Schritt 1, Bild 1 von 2 Huawei P8 Lite Battery Replacement, Loudspeaker: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Spudger
    $2.99
    Kaufen
    • Begin by removing the back cover of the device with the Spudger. To prevent damage to the back cover, begin removing the cover half an inch to the right of the headphone jack and continue prying around the perimeter of the device.
  2. Huawei P8 Lite Battery Replacement: Schritt 2, Bild 1 von 1
    T5 Torx Screwdriver
    $9.99
    Kaufen
  3. Huawei P8 Lite Battery Replacement: Schritt 3, Bild 1 von 2 Huawei P8 Lite Battery Replacement: Schritt 3, Bild 2 von 2
    Spudger
    $2.99
    Kaufen
    • Use the Spudger to gently remove the Loudspeaker from the device. Place the replacement Loudspeaker into the device.
  4. Huawei P8 Lite Battery Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Continue by removing the SIM and SD card trays on the side of the device.
  5. Huawei P8 Lite Battery Replacement: Schritt 5, Bild 1 von 3 Huawei P8 Lite Battery Replacement: Schritt 5, Bild 2 von 3 Huawei P8 Lite Battery Replacement: Schritt 5, Bild 3 von 3
    • Remove the two Torx T5 screws. One may be cover with a liquid indicator.
    • Remove the five Phillips #000 screws.
    • Take away both securing brackets covering the motherboard.
    • If your phone has an NFC antenna, taking away the cover will automatically free its flex connector from the motherboard.
  6. Huawei P8 Lite Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the three Phillips #000 screws on the silver panel.
  7. Huawei P8 Lite Battery Replacement: Schritt 7, Bild 1 von 2 Huawei P8 Lite Battery Replacement: Schritt 7, Bild 2 von 2
    • Carefully separate the four connectors holding the motherboard in place.
    • Remove the motherboard from the device.
  8. Huawei P8 Lite Battery Replacement, Battery: Schritt 8, Bild 1 von 1
    • Locate the adhesive strip underneath the battery. Gently pull on the strip to loosen it enough to remove the battery from the device.
  9. Huawei P8 Lite Battery Replacement: Schritt 9, Bild 1 von 1
    Spudger
    $2.99
    Kaufen
    • Use the Spudger to gently remove the battery. Then insert the replacement battery.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 1-1, Kass Spring 2017 Mitglied von USF Tampa, Team 1-1, Kass Spring 2017
USFT-KASS-S17S1G1
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,082
