Einleitung
This guide will explain how to replace the Earpiece Speaker for the Huawei P8 Lite.
Was du brauchst
Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
When all clips are open, remove the back cover from the rest of the phone.
Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
Continue by removing the SIM and SD card trays on the side of the device.
Remove the two Torx T5 screws. One may be cover with a liquid indicator.
Remove the five Phillips #000 screws.
Take away both securing brackets covering the motherboard.
Carefully separate the four connectors holding the motherboard in place.
Remove the motherboard from the device.
