Zum Hauptinhalt wechseln
Huawei P8 Lite Loudspeaker Replacement
Was du brauchst
  1. Huawei P8 Lite Loudspeaker Replacement, Remove  Back Cover and Loudspeaker: Schritt 1, Bild 1 von 2 Huawei P8 Lite Loudspeaker Replacement, Remove  Back Cover and Loudspeaker: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Spudger
    $2.99
    Kaufen
    • Use the Spudger tool to get access to the loudspeaker. Locate where the headphone jack is, then move about one-inch to the right and begin to gently pry the back-cover off the phone with the flat end of the Spudger tool. Make sure to pry apart the entire perimeter of the back-cover to prevent bending/cracking of the plastic.
    • Tools used: Spudger tool (used as a wedge to pry off the back-cover and loudspeaker.)
  2. Huawei P8 Lite Loudspeaker Replacement: Schritt 2, Bild 1 von 1
    • Remove three silver Phillips 000 screws.
    • Remove four T5 Torx screws.
  3. Huawei P8 Lite Loudspeaker Replacement: Schritt 3, Bild 1 von 2 Huawei P8 Lite Loudspeaker Replacement: Schritt 3, Bild 2 von 2
    Spudger
    $2.99
    Kaufen
    • Gently, use the flat end of the Spudger tool, or a metal opening tool to lift and remove the loudspeaker from the phone. The loudspeaker is the entire portion of the phone where the screws were extracted.
Abschluss
To reassemble your device, follow Teardown Guide steps 4, 3, 2, 1 in that order.
Eine weitere Person hat diese Anleitung absolviert.
Brayden Mann
639 Reputation
4 Anleitungen geschrieben
Metro State, Team 1-2, Carpenter Spring 2016 Mitglied von Metro State, Team 1-2, Carpenter Spring 2016
MSU-CARPENTER-S16S1G2
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 1,390
