Einleitung
Use this guide to replace the front facing camera in your Huawei P9.
Was du brauchst
First switch off your phone and remove the SIM card tray.
Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
Peel off the conducting fabric.
Unplug the camera connector.
Now you can remove the front camera.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
