Zum Hauptinhalt wechseln
  1. Remove back cover. Remove back cover. Remove back cover.
    • Remove back cover.
  2. Use the tweezers or some tools thin and sharp to cut the adhesive between power flex and bracket. And then pry it up and remove it. Use the tweezers or some tools thin and sharp to cut the adhesive between power flex and bracket. And then pry it up and remove it.
    • Use the tweezers or some tools thin and sharp to cut the adhesive between power flex and bracket. And then pry it up and remove it.
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
Sophia
43.326 Reputation
62 Anleitungen geschrieben
When you say follow the steps in reverse to finish the repair, what exactly happens with the glue melted in the first step? Do you just reheat the back cover to set it again, or do you need to apply your own glue? Similarly for the power flex. You mention you need to pry past the glue, does this indicate it also needs to be glued back into place?
Willem-Frederick ter Haar - Antwort
You have to add an adhesive on the edges of the back cover. Don't apply heat from the heat blower
clinton opara - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 2,028
