Zum Hauptinhalt wechseln
Huawei Pronto LTE Battery Replacement
Was du brauchst
  1. Huawei Pronto LTE Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Huawei Pronto LTE Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the back cover of your Huawei Pronto LTE using an opening tool.
    • Lift the back cover off of the device after the four corners are unlatched.
  2. Huawei Pronto LTE Battery Replacement: Schritt 2, Bild 1 von 3 Huawei Pronto LTE Battery Replacement: Schritt 2, Bild 2 von 3 Huawei Pronto LTE Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the 15 screws on the back of the device using a Phillips #000 screwdriver.
    • Hold the device in place while you are doing this step.
    • Lift the inner cover gently by using a spudger.
  3. Huawei Pronto LTE Battery Replacement: Schritt 3, Bild 1 von 3 Huawei Pronto LTE Battery Replacement: Schritt 3, Bild 2 von 3 Huawei Pronto LTE Battery Replacement: Schritt 3, Bild 3 von 3
    • Detach the yellow latches along the sides to remove the motherboard.
  4. Huawei Pronto LTE Battery Replacement: Schritt 4, Bild 1 von 3 Huawei Pronto LTE Battery Replacement: Schritt 4, Bild 2 von 3 Huawei Pronto LTE Battery Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Ensure that all latches are detached and that there are no extra screws to avoid damaging the motherboard.
    • Use tweezers to gently remove the motherboard from the device.
  5. Huawei Pronto LTE Battery Replacement: Schritt 5, Bild 1 von 3 Huawei Pronto LTE Battery Replacement: Schritt 5, Bild 2 von 3 Huawei Pronto LTE Battery Replacement: Schritt 5, Bild 3 von 3
    • The battery should be revealed once the motherboard is removed.
    • Lift the battery from the top left corner.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 875
