Einleitung
The battery is an essential component for the phones ability to function. This guide will clearly show you how to remove the battery without damaging other parts of the phone. Before you start please have the correct tools listed underneath as these tools will ensure a successful battery replacement.
Was du brauchst
Remove the back cover of your Huawei Pronto LTE using an opening tool.
Lift the back cover off of the device after the four corners are unlatched.
Remove the 15 screws on the back of the device using a Phillips #000 screwdriver.
Lift the inner cover gently by using a spudger.
The battery should be revealed once the motherboard is removed.
Lift the battery from the top left corner.
