Einleitung
The display screen is a vital part of the device. Seeing what you're doing on your phone helps to navigate each move you make in the correct order.
Was du brauchst
Remove the back cover of your Huawei Pronto LTE using an opening tool.
Lift the back cover off of the device after the four corners are unlatched.
Remove the 15 screws on the back of the device using a Phillips #000 screwdriver.
Lift the inner cover gently by using a spudger.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to gently remove the motherboard from the device.
The battery should be revealed once the motherboard is removed.
Lift the battery from the top left corner.
Remove the motherboard. Refer to the Motherboard Replacement Guide.
Remove the battery.
