Zum Hauptinhalt wechseln
Huawei Pronto LTE Rear Camera Replacement
Was du brauchst
  1. Huawei Pronto LTE Rear Camera Replacement, Rear Camera: Schritt 1, Bild 1 von 3 Huawei Pronto LTE Rear Camera Replacement, Rear Camera: Schritt 1, Bild 2 von 3 Huawei Pronto LTE Rear Camera Replacement, Rear Camera: Schritt 1, Bild 3 von 3
    • Use an Opening Tool and begin to lever up the back cover of your Huawei Pronto LTE
    • Make sure to do this all around the smartphone.
  2. Huawei Pronto LTE Rear Camera Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover.
    • Please keep all the removed smartphone pieces in a safe place. These pieces will be needed later.
  3. Huawei Pronto LTE Rear Camera Replacement: Schritt 3, Bild 1 von 2 Huawei Pronto LTE Rear Camera Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the fifteen 0.5mm screws with a Phillips #000 screwdriver.
  4. Huawei Pronto LTE Rear Camera Replacement: Schritt 4, Bild 1 von 3 Huawei Pronto LTE Rear Camera Replacement: Schritt 4, Bild 2 von 3 Huawei Pronto LTE Rear Camera Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Lift up the connectors with tweezers to disconnect them from the motherboard.
    • Then use the tweezer again to take off the motherboard.
  5. Huawei Pronto LTE Rear Camera Replacement: Schritt 5, Bild 1 von 2 Huawei Pronto LTE Rear Camera Replacement: Schritt 5, Bild 2 von 2
    • Release the connector.
    • Loosen the camera from the motherboard and take it out with the tweezers.
    • Do not touch the camera with your hands, only use tweezers.
Abschluss
Sonara
171 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 163
