Einleitung
If your Huawei SnapTo G-620 fails to charge the battery may need to be replaced. This guide shows how to replace your SnapTo's battery.
Was du brauchst
Pry open the back cover with your fingernail, using the divot to the lower left hand corner.
Remove all fifteen 4mm Phillips J00 screws on the back panel.
Using a metal spudger or your fingernail, remove the back panel.
Fast fertig!
Abschluss
