Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
If you are experiencing shutter delay with your Huawei SnapTo G-620's camera, then the camera may need to be replaced. This guide shows you how to replace your SnapTo's camera.
  1. Pry open the back cover with your fingernail, using the divot to the lower left hand corner. Remove all fifteen 4mm Phillips J00 screws on the back panel. Using a metal spudger or your fingernail, remove the back panel.
    • Pry open the back cover with your fingernail, using the divot to the lower left hand corner.
    • Remove all fifteen 4mm Phillips J00 screws on the back panel.
    • Using a metal spudger or your fingernail, remove the back panel.
  2. Use a plastic opening tool to remove the pictured flat-top connector. Using the plastic opening tool remove the camera.
    • Use a plastic opening tool to remove the pictured flat-top connector.
    • Using the plastic opening tool remove the camera.
Abschluss
Brian Omer Uzan
401 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S2-G6, Nance Fall 2017 Mitglied von USF Tampa, Team S2-G6, Nance Fall 2017
USFT-NANCE-F17S2G6
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 129
