Zum Hauptinhalt wechseln
Huawei SnapTo G-620 Microphone Replacement
Was du brauchst
  1. Huawei SnapTo G-620 Microphone Replacement, Battery: Schritt 1, Bild 1 von 3 Huawei SnapTo G-620 Microphone Replacement, Battery: Schritt 1, Bild 2 von 3 Huawei SnapTo G-620 Microphone Replacement, Battery: Schritt 1, Bild 3 von 3
    • Pry open the back cover with your fingernail, using the divot to the lower left hand corner.
    • Remove all fifteen 4mm Phillips J00 screws on the back panel.
    • Using a metal spudger or your fingernail, remove the back panel.
  2. Huawei SnapTo G-620 Microphone Replacement: Schritt 2, Bild 1 von 1
    • Remove the pictured 4mm Phillips J00 screw.
  3. Huawei SnapTo G-620 Microphone Replacement: Schritt 3, Bild 1 von 2 Huawei SnapTo G-620 Microphone Replacement: Schritt 3, Bild 2 von 2
    • Use a plastic opening tool to remove the pictured flat-top connector.
  4. Huawei SnapTo G-620 Microphone Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery.
  5. Huawei SnapTo G-620 Microphone Replacement, Microphone: Schritt 5, Bild 1 von 2 Huawei SnapTo G-620 Microphone Replacement, Microphone: Schritt 5, Bild 2 von 2
    • Using the plastic opening tool remove the camera.
  6. Huawei SnapTo G-620 Microphone Replacement: Schritt 6, Bild 1 von 3 Huawei SnapTo G-620 Microphone Replacement: Schritt 6, Bild 2 von 3 Huawei SnapTo G-620 Microphone Replacement: Schritt 6, Bild 3 von 3
    • Use the plastic opening tool to remove all the remaining flat-top connectors.
  7. Huawei SnapTo G-620 Microphone Replacement: Schritt 7, Bild 1 von 3 Huawei SnapTo G-620 Microphone Replacement: Schritt 7, Bild 2 von 3 Huawei SnapTo G-620 Microphone Replacement: Schritt 7, Bild 3 von 3
    • Using the spudger, pry open the zif connector, and remove the cable.
  8. Huawei SnapTo G-620 Microphone Replacement: Schritt 8, Bild 1 von 2 Huawei SnapTo G-620 Microphone Replacement: Schritt 8, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers or the spudger, remove the microphone.
Abschluss
Coleson Perry
101 Reputation
1 Anleitung geschrieben
USF Tampa, Team S2-G6, Nance Fall 2017 Mitglied von USF Tampa, Team S2-G6, Nance Fall 2017
USFT-NANCE-F17S2G6
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 225
